Wire Feed Not Working on MIG 135
Posted: July 12, 2011 By: 57tbirdguy
Home Forums Ask Eastwood Wire Feed Not Working on MIG 135
  • #33830
    57tbirdguy
    I received my MIG 135 about a year ago. I welded with it a few times and haven’t used it since winter. I was attempting to complete a project tonight and plugged my welder into the outlet and it powers up but the wire feed wheel doesn’t move. When I push the trigger the welder clicks so I know the switch is working properly. I disconnected all the hookups for the gun and reconnected them to make sure nothing was loose. I also removed the welding wire to make sure nothing was jammed to no avail. I have rotated both the wire speed and heat settings and the wire spool doesn’t budge. I’m bummed because I’ve only welded with it two times and it worked great. Help!
