I have a 68 Camaro that I just removed the back glass. The metal is not that bad except the upper channel by the roof. There are a few small holes. The question is should I attempt to wire wheel area and then try to weld the holes ( I am not a pro) or is there another solution. I know body filler attracts more moisture.
