I am making my first attempt at body work and have a few questions. The portions being worked on are in sandable primer and I would like to know what grit paper should I start and finish with. can I do this with my hand, a DA or on a sanding block? Do I remove as much primer as I can like a final top coat of filler or do I want the panel to all be the color of the primer with no sand through’s?
You help is appreciated
Kevin R
