Welding in replacement piece to my Truck Crew Cab
  • #27130
    satexasuser
    I’m going to be replacing a Driver side Damaged Section of My crew cab “Cab” with a Slavage replacement Cab Piece . My question is this: I’m going to butt weld the two pieces together(the replacement cab part to the existing cab on my truck) using a 110 MIG welder. When I bead well the cab should I weld on both the interior and exterior of the cab or just the inside of the cab. Also what type of clamps would you recomend using to hold in place the cab replacement as I weld it?
    Thanks in Advance
    Mario P
