Versa 60
  • #35712
    Jdon
    Hi guys I am extremely impressed with my mig175 and versa 60!
    I have a couple quick questions
    1. The PDF version on the site for the psi and power for the versa 60 is different then the manual. The manual says 60 for all sizes of metal. should I run 60 for everything?
    2. When I pull the trigger and I’m set at 60 the pressure gauge drops should I adjust the machine regulator to 70
    I have a dual stage compressor so supply air is not a problem
    3. I haven’t found any instructions on draining the last chance built into the machine. Do you have to tip the machine on its side to drain.
    Thank you your equipment is great and the instructional videos are well done
    Jeff
