using compounds
- This topic has 0 replies, 1 voice, and was last updated 17 years, 3 months ago by .
ok i just finished wet sanding to 2000 grit. and im about to start using compounds. i started with emery on a sewn stitch wheel. and i noticed alot of light scratches on the part. will these go away as i progress through the other compounds. also what should i look for and expect to see as i work my way through the colors.
the part is aluminum sport bike pieces i was planning on going from emery tripolie, jewlers and then white. does this sound right. sorry for all the questions but im learning as i go.
