Using 3M epoxy on body seams
  • #31838
    I have a 65 Dodge A100 pickup I’m working on. I’d like to fill the body seams and want to know if using 3M epoxy used to fuse panels would be a good choice. I really don’t want to weld all the seams and realize that just filler may crack and fall out. I already replaced one top bedside rail with epoxy so welding it would destroy that seam. My thinking was to lay a bead down each seam after a through cleaning with a grinder. Then smooth it with a skim of filler to level and finish. What do you think? Is there a better way? Thanks in advance. Ron
