Undercarriage Coating
  • #31783
    schultz51
    I am restoring a 64 Impala SS as a driver. The car was bead/sand blasted inside, outside, undercarriage and frame. I have replaced the floor pans and just finished using 3M seam sealer around the welded sections in the floor. I am getting ready to prime the underside using Mar-Hyde urethane primer. What kind of paint/coating would you recommend to use over the primer?
