two coats help
  • #35945
    copachino
    hi, i just have a eastwood hot coat and its quite good as for the base colors but, im trying to use on some aluminium rims(mine) and i used ultimate chrome for the base and i want to use candy blue over the top, but whenever i shoot the candy the powder does not stick over the metal and get blowed by the same gun, even at 5 psi, i look to see the spark and th spark its a bit weak, so must be a ground issue, but the main thing would be, can i solve the ground with the hotcoat, or i need to get something like the dual voltage thing to shoot two layer of powder??
