i have been able to remove about 90% of the surface rust in the trunk of my 66 mustang. there are a few areas that i cannot get to with mechanical means. i am thinking of using your chemical rust remover followed by your rust encapsulator. will this give me satisfactory results? other than wiping down the area with thinner before application and sanding with a 320 grit paper before top coat is there any thing else that should be done thanks ed
