Question: After sanding panels and treating rust, can I use the polyester primer surfacer to prime DTM and start filler work or not? Also the original factory paint is whats left on the vehicle and if i only sand through to the original primer can i use the same procedure. Or…do I need to use an epoxy primer first then do body filler then go with polyester primer??
