Torch fitting adapters for TIG200 ? (want to adapt my water cooled torch etc)
Posted: December 25, 2011 By: Piledriver
Home Forums Ask Eastwood Torch fitting adapters for TIG200 ? (want to adapt my water cooled torch etc)
  • #34073
    Piledriver
    What is the spec/name of the existing gun side fitting on the TIG200?
    I have a very compact head water cooled torch I’d like to hook up, but of course nothing is ever easy, as the water cooled torch flows coolant down the power line connection, gas feed and return use separate lines, and none of the fittings match (of course)
    It’s a handy torch for very limited access locations, (like inside intake ports) it will fit when nothing else will.
    It would also be nice to be able to use the TIG200 to burn some sticks for heavier apps, with a std Dinse connector on both sides.
    I also have a spool gun setup that I can use with a CC supply, (it has its own 24v speed control/power setup) same deal.
    Can the TIG200 be set up as a std CC supply? (controlling it is trivial)
    Bought mine a couple weeks ago, weather and time off looks like I might finally get to do more than play with it tomorrow.
