Hi Kevin,
The instructions for Eastwood’s epoxy primer say to use a 1.4 to 1.8 tip for HVLP. But in one of the Hands on Cars segments, you say to use a 1.3 tip (there is a short outtake here: https://www.youtube.com/watch?v=N21QACpotsA).
In that clip, however, you are using the epoxy as a sealer, rather than a primer. Do you recommend a 1.3 tip for all applications, or was it just because you were applying it as a sealer?
Thanks!
