I am welding a 22g steel sump baffle onto a 18g sump. Using standard cleaning and set up I am either getting burn through of the thin material or no penetration into the thicker material. Heat rings are showing through the sump but the pieces are not welding together. I’m nervous about experimenting too much as this is a 1960 Jaguar XK150 sump and hard to replace.
