The only surviving 1:4 scale Dodge Viper V10 motor castings.
  • #32318
    TANGO
    Limited Edition Viper V10 Collector Castings
    The following list is of the
    only surviving 1:4 scale Dodge Viper V10 motor castings. There is one complete
    running motor on a test stand the price if any one is seriously interested is in
    the $250,000.00 range.
    The casting groups listed below are the ultimate
    automotive collector item. These are the castings that the fully detailed
    running motor was to be constructed from. Some of these castings are imperfect,
    some are finished machined but most are fresh castings never finished. We have
    assembled them in groups to best show their detail.
    1:4 scale Dodge Viper V10 Casting Set 1:
    Most Complete
    Motor
    – $6,500.00 (1 Available)
    * Partially machined V10 block
    * Crank shaft blank not machined
    * Two fully machined heads
    * Two perfect exhaust manifolds
    * Intake manifold
    * Two finished rocker arm covers
    * Partially machined front cover
    * Unfinished power steering pump
    * Unfinished AC compressor
    * Spin on oil filter and oil pan
    * One spark plug
    * One valve
    * One connecting rod
    1:4 scale Dodge Viper V10 Casting Set 2:
    Second Most
    Complete Motor
    – $5,500.00 (1 Available)
    * Intake manifold
    * One spark plug and one valve
    * Oil pan
    * One Exhaust Manifold (incomplete casting)
