I understand the part has to be at temp before lowering to 400 for the 20 min cure cycle. I’ve checked temps during the cure cycle and found them higher than the 400. Is that because of “false” ir readings off of the pc or?? :confused:
Sooo, regulate the part temp or set the oven temp and leave it? It sounds like a dumb ques, but I just had to ask! 😀
