Stuck bearing races and Piston sleeve inserts.
- This topic has 0 replies, 1 voice, and was last updated 17 years, 2 months ago by .
Removing stuck/stuborn bearing races and piston sleeve inserts can be a chore. Here’s a trick… run a weld bead around the inside of the race or piston sleeve and wha…la, they almost fall out.
