Stripping/Coating Polished Aluminum
  • #30217
    Joe
    Hello all,
    I have a few pieces from a 2005 Triumph Bonneville (primary case cover, rocker box cover and chain guard) that I will be prepping/powdercoating in the next few weeks. They are polished aluminum and I’m not sure of the best way to strip/prep the surface. Any ideas?
    Also, once prep’d – should I use primer, then powdercoat? I’m a bit concerned for the primary case cover as that gets a bit more wear and tear than the other two.
    Thanks in advance for your help.
