Sprying high-build primer
  • #31975
    eking66756
    What size tip is needed for spraying high-build primer. My gun from Eastwood has a 2.0 tip. Also, if a larger tip is needed, the only identification on the gun is H827W. It is an HVLP purchased about 3 years ago. It was pretty cheap as I recall. Under $100. Thought I would use it for primers, etc. Do you have larger tips for this gun?
