Spray guns, body work, 42 dodge
  • #31970
    g8trwood
    Well I am entering the realm of body work with a 42 dodge military truck. I had the truck dipped to remove all the rust and lead based paint. I need to protect the truck while I am doing the body work and my thoughts are to epoxy prime the whole project and then remove the primer in the areas I need to work on in order to keep the body from flash rusting (fl and long term project)
    If I epoxy prime, should I then put a sanding primer on top or for a long term project will the sanding primer contaminate too easily. The car is in a garage dedicated to this project.
    I have an astro HVLP gun that I use for woodworking, 1.5 tip, would that be okay for some of the primers? And what gun would you recommend (mid range please) for a novice. I have an 80 gallon, 5 horse compressor.
    And Yes, I did start with several of your videos.:)
