This is my first project and my first crack at body work. I am in the process of hiding as best as possible all the wires in the engine bay and filling all the holes (big and small). My thought is to use Eastwood’s structural adhesive to secure sheet metal behind the larger holes and then use body filler to fill in and smooth. I think I can use structural adhesive to fill the smaller screw holes and sand down. My questions for all of you.
1) will what I described work?
2) is there a better way to achieve the end goal? I do not have a welder or know how to weld.
3) any advice on the products mentioned?
4) which body filler will be easiest for a newbie?
