Single Stage
  • #33883
    mdcowby
    I’m using EW white, How long after spraying a door or hood with single stage can you touch up areas if you missed them, I noticed a few bad spots below my door and a indention on the hood, can I lightly sand and fill these areas with spot glazing then re-prime, also can I just touch up the area or do I need to re spray the whole door. will these areas blend in or do I need to re tape everything and hit the whole door again.. My question is after spraying like a door how long do I need to wait before I can mess with it, do I have to wait till the next day, just doing this in my garage normal air drying.. Also when can I wet sand and polish, Thanks
