First off, I love Eastwood and all their products!
A brief overview of my progress:
- Stripped to steel
- Fillers and body work done
- Applied Epoxy Primer
- 1 day flash and topcoated with Contour Polyester
- Blocked after a week with 320
- Second application of Poly for minor imperfections
- After a week, topcoated with 2k Primer Surfacer
- Another week will pass before going over the 2k with 600 dry
When I am ready to spray the base (single stage boulevard black), I plan on reducing with 4:1:1 with a medium reducer and a 1.4 tip. I will probably do 3 coats and allow a week for this to “cure”. I am also planning to topcoat this with Eastwood 2:1 High Solids European Clear at a 2:1:1 mix with a 1.3 tip after a week of “cure” as well.
Now, here are a few questions that I have:
- Should I block the single stage with 600 wet before laying on the clear, or what grit is recommended before clearing?
- After 2-3 coats of initial clear, after a week, sanding with 600 wet again, applying 2-3 more coats. Should I sand the clear with 600 for prepping the next coats of clear?
- After the last coats of clear, the panels will “cure” in a 70* temp. for about a week before being put in a cold storage shed outside for roughly 2-3 months while the rest of the car is worked on. Will this temperature variation (could reach 0* temps) affect the final curing process?
After this, I will mount the panels, then sand with 1500 initial, moving to 2000, 2500 and 3000 before buffing.
Thank you for any help you can provide!
Adam
