Hi there, I have just purchased your soda blaster (Y50095) here in the UK. I would like to know (because the outlet selling your products does no know) is my compressor ok (14 cfp, 200lt tank)? Its does run all the time when blasting so I just wondered how long I could keep going for before it needs a break? Also which of the tips you supplied am I supposed to use (I am using Ali Oxide 60 grit)? The tip I have used seems to be wearing very quickly….how long do they last? And lastly what pressure do I run the blaster at? I am blasting 3 Land Rover bodies by the way. Thanks in advance. Kevin
