Satin Black on beadblasted spoked wheels
- This topic has 0 replies, 1 voice, and was last updated 11 years, 4 months ago by .
I have a set of laced motorcycle wheels that have steel spokes attached to an aluminum hub. I plan to bead blast the assembled and trued wheel with glass beads, and want to pain the whole shebang in a satin black sans primer.
What do you recommend that doesn’t take a primer to adhere to? Should I use the post-sandblast spray you sell to give the paint some stick?
Could I paint with the SEM Trim Black (made for adhering to bare metal) and then coat with the Hot Rod Satin clear?
I plan to bead blast, wipe down with wax/grease remover, bake at 100C, then wipe with a tack and paint.
If going without primer (to not add undo thickness to the features like spoke nipples) is a definite no-no, is the Diamond Clear Satin for bare metal the next best choice. It will give it a nice industrial look, but an all black wheel is my preferred look.
