Sanding grit question
  • #35591
    TCannon
    Hello Eastwood guys, I have a question about the proper sanding grit. In one of Kevin’s videos, he talked about using 600 grit instead of 400 grit paper to finish sanding if you are using metal flake paint. But does this still matter if you are going to spray a seal coat of epoxy primer before the base coat? Thanks again!
