Sag/Runs in base coat
  • #28030
    cd55
    Question from a noobie.
    I have a beater car to practice on. But, I would like to do a decent job.
    I plan on doing 3 base coats and 3 clear coats. But, let just say. I probably will end up with a few runs or sags. 😮
    If I should get a sag or run during the base coat spray. Should I stop and wait till the 1st coat has cured and sand it out or just spray all the coats?. Then remove the problem with fine sanding.
    The same would go for the clear coat?
    What would you do?
