I have some rust just starting along the door panel seam on the inside bottom of the door, you know the spot where the water that doesn’t make it out the drain holes sits, well I need to take care of this problem now and was wondering which of your products you would recommend and in what order. I would obviously treat this from inside thru the door panel with a rust dissolver or converter that can penetrate where the water did, and when the rust is taken care of, seal it from reoccurance. What do you recommend?
Gary S
