I’m building a 1936 Dodge sedan. It has a “C” shaped frame. I plan on blasting the frame completely but I want to box the outer frame rails and make them tube shape. I can media blast the inside of the “C” shaped frame now.
What is the best thing to rust treat the inside of the frame and the box plate before welding them together:confused:? (Picklex 20 w/ weld thru primer?)
Do you have products that can be applied and then welded or would they need to be treated after welding?
Any help would be greatly appreciated.
John – Chesapeake, VA
