Rust Encapsulator questions
- This topic has 0 replies, 1 voice, and was last updated 16 years, 9 months ago by .
I’ve got alot of questions about RE. I’m about to start the work on my truck so I want to make sure.
If I brush on the RE will there be lines? do I want a few light coats or heavy coats if I choose to spray it? Does the metal need to be scuffed for RE to stick to it? Should body filler be used on bare metal first then RE sprayed over it? Does body filler stick to RE or should it be scuffed? Does RE need to be scuffed for epoxy primer to stick to it? Will RE block future rust on clean metal or does it not need it to be safe? Does RE only convert not protect?
thanks in advacne sorry for so many questions
