This message has been posted for Rick.
Is Eastwood rust encapsulator sandable? If I use encapsulator as a primer coat can I sand it before putting on enamel final coat or do I have to use another primer over encapsulator? What would be my steps to a fine finish?
1. Dissolve rust, 2. Encapsulator, 3. Sand, 4. Coat with enamel? I need to obtain a fine glossy finish under any color enamel. Is there any special precautions I need to take in applying encapsulator with aerosol can? Mask, clean air source, etc. or is it the same as enamel? Thanks for the information, Rick
