I plan to pick up your 1:1 epoxy but had a quick question – I have a fair amount of surface rust under the dash and other areas of the floor pan. Obviously this will all be covered up so I don’t want to waste too much time with the rust. Can I spray the rust converter on the surface rust then put the epoxy on after? Will that prevent additional rust? With the epoxy adhere to the rust converter?
Thanks in advance!
