resistor in line with ground on hobbie gun?
To help reduce problems of getting into tight corners with the hobbie could you use a resistor between the ground wire and the part? This is just a what if question for everyone to ponder. I believe the corners and nooks and crannies problems are related to faraday cage effect (sp?). I got the idea after reading another post and wanted to through the idea out there what is everyones thoughts?
