Hi:
I’m in the middle of restoring a vintage King porch glider–it’s mostly in great shape, but has some pitting, small holes, and few 5-6″ cracks in the seat, which is sheet metal. It was manufactured in the 1950’s; I had a welder come over, but he suggested I try gluing a patch panel on instead.
My plan was:
– get a 16-gauge sheet of sheet metal, about 20×10″
– bend it to match curve, drill holes using step bit that are slightly larger than square holes in seat
– glue panel to underside of seat
– use body filler to fill in pits, smooth out surface
– prime and paint
I was considering using:
– No Weld Panel Adhesive Replacement — 31087
– Eastwood Contour Aluminum Repair Compound 25.3 oz — 13518ZP
I’m working on a very limited budget (out of work), so I don’t want too much excess material. I also need it to have decent strength, as it’s a seat; handle temperature changes and humidity (outdoors in Georgia); and be easy to work with. I’ve worked with epoxies and body fillers some in the fast, so not a total novice.
Any suggestions? Thanks!
-Mark-
[ATTACH]4966[/ATTACH][ATTACH]4963[/ATTACH][ATTACH]4964[/ATTACH][ATTACH]4965[/ATTACH]
