Repair shows after painting. Help, por favor!
  • #29948
    xaviermxp
    Howdy,
    relatively new at this bondoing, painting biz. i’ve done about 1/2 dozen patch jobs — fenders, rust repair, etc. But, almost every time i spray primer over the bondo/filler patch, i can see the point where the bondo meets the metal — thru the paint. What am i doing wrong?
    I suspect i’m sanding too much filler off. I’m trying to get it even with the surface of the car, but by the time i get it sanded down to that point, seems like i’ve gone too far.
    should i maybe feather the bondo or filler — typically, i end up using some type of fiberglass filler, then glazing putty over it — an inch or two beyond the point where it meets the metal? Just concerned that it will then be higher than the rest of the car.
    thanks, in advance.
    Mark
