repaint
  • #33379
    jonhutch
    I have primed all repaired areas with 2k urethane after sanding some areas i have gone down past the oem clear and into the base.
    Do theses areas need to be primed again before final sanding? The car is silver and i am painting using eastwoods silver do i need to spray some type of sealer to get a even base. When painting car do I need to spray a coat on primed areas first before spraying full panels? Thanks Jon
