Removing oxidation from cast aluminum?
Posted: February 11, 2006 By: Helf8704
Home Forums Powder Coating Powder Coating Archives Removing oxidation from cast aluminum?
  • #28536
    Helf8704
    What do you guys use to remove oxidation from cast aluminum? I have an old school Turbo Dodge valve cover I’m trying to clean up to coat and there is oxidation all over it. I sandblasted it, tried using a scotchbrite pad, sanded it with 220 grit sandpaper but there is still oxidation in the metal. Will this show through if I coat over it? I’m guessing so, that is why I’m looking for other options. I do have a couple other things I’m going to try but any help would be appreciated. Thanks,
    Jason
