Quick questions for a newbie.
When I do a two coat process (clear top coat or or special effect over a base) I pre heat to gas off and then let stand to cool down to around 150. Then apply base and cure for about 10 minutes @ 375 let cool down and hit the second or top coat and finish off for 20-25 minuts at 375 ? Or do I just do the base like normal let it cure and start the second coat as I would the first after it cools. I know this is wide open and could have 50 answers depending on the product and desired final effect. But some starting info would be helpful
Mark
