Sealer: Nason Dupont Select 422-23 Acrylic sealer Flast time 10min
Basecoat: Dupont Chromabase basecoat Flast time 10mins
Clear: Nason Dupont Selectclear 496-00 Urethane clearcoat
Painting engine compartment
Questions
1) Can I spray 2 coats sealer then 2 coats of basecoat then 2 coats of clear all same day if I just wait the flash time between coats?
2) Should I sand before 2 coat sealer? After base coat do I sand 400grit apply another coat then sand with lighter paper then apply clear?
3) I purchased a east wood paint gun and the gauge that connects to the paint gun has a gauge that is in increments of 10psi how do I setup the gun for 7psi?
4) What tip should I use to spray sealer and clearcoat?
5) between paint changes I was going to use lacquer thinner to clean the gun is that ok?
6) Any other tips that you can provide me would be helpful 🙂
