Product Help for ’48 Ford Coupe!
- This topic has 0 replies, 1 voice, and was last updated 12 years, 8 months ago by .
I’m working on a ’48 Ford Coupe and I’ve sandblasted the paint from the rear wheel wells and about 70% of the metal is clean, but the remaining 30% has rust pitted areas. Will “Rust Converter” adhere to the clean metal as well as the pitted areas? If not, what product do you reccommend that I use? After applying the product, what high fill primer can I use to fill the pits? Should the filler be applied immediately? Is there a product that can be applied after the primer since the surface will not be painted for ~ six months? Any suggestions will be greatly appreciated!
