Priming as I go…
- This topic has 0 replies, 1 voice, and was last updated 11 years, 4 months ago by .
Hey guys,
I’ve come across a lot of conflicting info on what type of primer to use on my project. I’ve been using Eastwood’s process on the front frame so far with great results (internal frame coating, rust converter, rust encapsulator, extreme chassis black), but I’m not sure what to do with the body shell. I’ll be cutting and welding in new panels in all the usual places as the cash flow allows. What would you best recommend I cover the new fresh sections with as I go? Eventually it will be a pretty standard setup: red oxide epoxy primer interior and underside, trunk spatter, rubberized coating in the wheel-wells, and undecided exterior colour, but thats at least a year away. The car will always be inside the garage too. Any suggestions will be appreciated. Thanks
