Ok, so I am an amateur. couple of monumental faux pas. First, I correctly used a quality automotive primer but then used spray can primer for touching up a couple of spots I sanded through and now have those spots showing through the basecoat. Also some sanding scratches are showing through. Can I put on more basecoat after I allow it to fully cure and be pretty sure it wont bleed through more? Its black basecoat and will show in the plain as day. Also can I sand the basecoat? This would eliminate the scratches I think. It’s been 24 hours but the basecoat doesnt respond to sanding yet (probably not cured enough?). :confused:
