primer tips
  • #27389
    montepower
    Hello and good day. my question is, I am about to repaint my monte ss. the paint and body is good. I have removed the clear coat and had sanded the paint with 160 grit paper. In doing so I have about half dozen bare metal spots about the size of a 50 cent piece. I am going to use a two part urethane primer. Will I need to use a direct to metal primer on these areas first? or will the urethane primer be sufficient? Also the man at the counter said to use the entire gallon on my car? Is this too much. Can there be too much?? thanks for any info—mike in Tn. P.S. the car is an 83 monte ss
