I have a 56 ford pickup that I am restoring. I have completed all my welding and grinding. I than sprayed the truck with rust encapsulator and than did all body filler work and had sanded it. I did sand some areas to bare metal. I now plan to spray the truck with “slick sand primer” or can I use epoxy primer? I plan to paint the truck with acrylic enamel. Am I on the right track? Any suggestions you have would be very helpful as I am new to this. What other things I should do to prep the truck prior to painting? Thanks, jim
