Prepping and painting frame after blasting
- This topic has 0 replies, 1 voice, and was last updated 7 years, 7 months ago by .
I have a ’64 Galaxie frame that has the usual surface rust and scale. I am going to have the frame blasted at my house with the dustless blasting system. My question is, after it’s blasted what should be my next steps? Should I use After Blast on the frame right after it’s blasted? Should I then follow this up with a primer then paint. Do you offer a self leveling brush on system, if not spraying it on will be fine. What would you recommend for a good quality job that will last and prevent the return of any rust. Again the frame will be blasted, so any system that relies on rust to adhere/bond to Will not be able too. Thanks
