Equipment, es-02 with faraday wave, dedicated 8′ grounding rod with 4 guage wire, ew satin black, aluminum rims with 1 coat of kl primer. Ive turned kv’s down to 20-30 and even lower along with feed air and aux air thinking that the air pressure might be blowing the powder off. The ground has been hooked up directly to the rim as well as the hanging rod ive tried heating the rim up to 180 and still no good. I heated the rim up to 210 but the powder melted to the metal that is showing after sanding and made the finish bumpy.Any suggestions???? PLEASE HELP NEED TO BE DONE TONIGHT!!!
