Powder coating video question
  • #34937
    Meangreen
    I have watched all the videos and am wondering about when the guy powder coats the header or rim. When you powder coat something with two sides like that how do you make sure both sides get covered and cured? Also if you tape off some of you part to prevent coverage, how do you protect the metal after you are done powder coating? I have used a metal prep in the past and it seems I get surface rust fairly shortly after usage. Normally when I paint I first use a rust preventative then I prime and paint. Thanks
