powder coating primer question !!!!!!!
  • #32462
    kryptonite
    Hey Eastwood !
    Question……..once I have sprayed wheel with primer powder coat…how long generaly speaking does one let it flow or cure in the oven before…applying base coat…? I have read that one should let the primer flow out…and then remove from oven not letting primer completely cure….and then apply base coat…..and cure………??? Need the advise !! I am using Eastwood Hotcoat Powders……a grey primer….argent silver base coat….and then a clear coat……Need all the advise I can get…:rolleyes:
