Polishing Stainless
- This topic has 0 replies, 1 voice, and was last updated 17 years ago by .
I am trying to polish stainless from a 57 Ford Retractable. I have watched the Eastwood video and have most of the buffs/compounds. I do not have the “rake” to clean the wheels. I have been using a wood rasp. I use the wheels mounted on my drill press–A little slow (about 2350) but ok.
I am having a problem removing the marks made by the sisal wheel with emory. After the sisal/emery, I am using a spiral sewn wheel with stainless, but even if I buff to almost burning the stainless, I can see the marks left by the emery/sisal wheel if piece is held at correct angle and light.–HELP.
Note: The spiral sewn/stainless wheel seems to “load up” quickly and must be cleaned regularly.
If you have any suggestions or comments, they will be greatly appreciated.
Thanks :confused:
