polishing large aluminum tanks
  • #31988
    paulpenuel
    hello crew. I am trying to polish the large aluminum fuel tanks on a semi-truck. What would you recommend? I have a right-angle hand held buffer with a 7 inch wheel on it. I’ve tried the brick or stick type compound but it keep tearing up my bonnets when I try to apply it, even with very little pressure. What little I can get on the bonnets does a great job. Is there a different style compound I should use such as a paste or softer type that applies to my bonnets much easier? Thanks for any help you can direct my way
